Flow sensor
Close filters
SEN Digmesa Durchflusssensor G1/4 (5,6mm) (ohne Kabel) Digmesa flow sensor G1/4 (5.6mm) (without cable)
This flow sensor is integrated into the cooling circuit and enables continuous flow measurement. The sensor can be connected to an aquaero 4.00 USB fan controller or to the poweradjust USB pump controller using the separately available...
€33.67 *
SEN Alphacool ES Durchfluss- und Temperatursensor "HighFlow" mit Tachosignal Alphacool ES flow and temperature indicator "HighFlow" with RPM-Signal
The Alphacool ES "HighFlow" with tacho signal is a sensor for water temperature and water flow that can be easily integrated into any water circuit. Integration made easy The Alphacool ES "HighFlow" flow and temperature sensor is very...
€41.98 *
