Alphacool Eisblock Aurora backplate GPX-A Radeon RX 5700/5700XT Reference
  • 12958
  • 4250197129589
  • 0,228 kg
€9.98 * €20.00 * (50.1% Saved)
The Alphacool Eisblock Aurora Backplate GPX-A for the Radeon RX 5700 and RX 5700 XT reference... more
The Alphacool Eisblock Aurora Backplate GPX-A for the Radeon RX 5700 and RX 5700 XT reference design is the ideal addition to the matching cooling block. This backplate is compatible with all Alphacool Eisblock Aurora GPX-A GPU coolers that were specifically developed for the Radeon RX 5700 and RX 5700 XT and use the reference PCB. It provides optimized cooling of the rear side and adds extra stability to the graphics card.
Made from high-quality aluminum, the backplate improves passive heat dissipation of rear-mounted components, contributing to lower overall system temperatures. At the same time, it protects the PCB from mechanical stress and gives the graphics card a clean and well-organized appearance.
Material: Aluminum
Hardware manufacturers: AMD
