Alphacool ES Tube Teflon/PA/TPV 8/5mm - Black - 50m role
- Article no.: 10257
- EAN: 4250197102575
- Weight: 1,6 kg
The Alphacool ES Teflon/PA/TPV tubing from the Enterprise Solutions series is designed to meet the highest demands in professional environments. Thanks to its special material composition of Teflon, Polyamide (PA), and Thermoplastic Vulcanizate (TPV), it combines the best properties of different materials and offers significantly higher resistance compared to conventional PVC tubing.
The robust construction not only ensures exceptional durability but also outstanding resistance. The tubing provides high resistance to acids, bases, and a wide range of aggressive substances often encountered in industrial or scientific environments. External factors such as heat, moisture, or mechanical stress also have little impact on its performance. The ES Teflon/PA/TPV tubing offers significantly greater temperature resistance, allowing for operating temperatures well above 100 °C. Even at higher coolant temperatures, the tubing remains dimensionally stable and prevents deformation in areas with tight bending radii or fittings. These properties make the ES Teflon/PA/TPV tubing a sustainable and cost-effective solution for continuous operation.
Its robust design also ensures excellent dimensional stability. Kinks or deformations are effectively minimized, guaranteeing consistent coolant flow under all operating conditions. At the same time, the tubing remains flexible enough to be routed easily in tight server racks or complex workstation setups.
Optimized for use in data centers, workstations, and industrial cooling systems, the ES tubing plays a key role in ensuring operational reliability and continuity. It meets the high demands of modern IT infrastructures, where dependable cooling is a critical factor for both performance and hardware longevity.
| Technical data | |
| Length | 50 m |
| Material tube | Teflon (PTFE), Polyamide (PA), and Thermoplastic Vulcanizate (TPV) |
| Tube size | 8/5 mm |
| Tube inner diameter | 5 mm (tolerances according to DIN ISO 33-02-1 E1) |
| Tube outer diameter | 8 mm (tolerances according to DIN ISO 33-02-1 E1) |
| Fitting connection size | 8/5 mm |
| Color | matt black |
| Weight | 97 g |
| Hardness | Shore 75A |
| Maximum working pressure at 60°C (140°F) | 6.0 bar |
| Maximum working pressure at 90°C (194°F) | 4.0 bar |
| Maximum operating temperature | 100 °C (212 °F) |
| Minimum operating temperature | -40 °C (-40 °F) |
| Flame class / flame resistance | UL94-HB |
Warranty: 10 years
