Alphacool ES 2xMCX distributor for 12.7/7.6mm with barbed connection brass
- Article no.: 14645
- EAN: 4250197146456
- Weight: 0,02 kg
The Alphacool ES 2xMCX manifold is a compact, robust solution for integrating MCX components into a cooling loop with 12.7/7.6 mm tubing. Designed for professional use in industrial, server, and workstation environments, this manifold combines maximum reliability with a space-saving form factor.
Manufactured entirely from solid brass, the manifold offers high resistance to pressure and corrosion, ensuring long-term durability even in 24/7 operations. The natural brass finish emphasizes its technical and industrial character.
The integrated barbed fittings are designed for 12.7 mm outer diameter and 7.6 mm inner diameter tubing. They offer a secure grip without the need for additional compression fittings, streamlining installation in confined environments.
Equipped with inlet and outlet, the manifold enables the direct integration of MCX components into the cooling loop. This is particularly useful for temperature monitoring or flow control in critical systems.
Whether used in a data center, industrial cooling unit, or high-performance computing system, the Alphacool ES 2xMCX manifold delivers uncompromising reliability and functionality — precisely what professionals need.
Technical data | |
Type: | Distributor with tube connection for low flow rates |
Dimensions: | 60,50 mm x 19,70 mm |
Nominal diameter: | 10,20 mm |
Connection type: | barbed fitting for tube (2x 12.7/7.6mm & 2x MCX) |
Material: | brass (CuZn39Pb3) |
Working pressure: | 2bar |
Burst pressure: | 8bar |
Working temperature: | -20℃ ~ +100℃ |
Recommended liquids: | water, deionized water, glycol water, propanediol water etc. |
Weight: | 15g |
Color: | brass, raw |
Hersteller: | Alphacool; |
Compatibility: | Soft hoses (PVC, silicone, neoprene); |
Material: | Brass |
