B-stock Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI Strix/TUF with backplate
KOI B-Ware Alphacool Eiswolf 2 AIO - 360mm RTX 3090 TI Strix/TUF mit Backplate EOL
  • 1025472
  • 4049469338763
  • 5,42 kg
€94.49 * €149.98 * (37% Saved)
This is a B-stock item . It is a returned product that has already been opened. Some thermal... more
This is a B-stock item.
It is a returned product that has already been opened. Some thermal pads are already pre-applied to the cooler but still covered with protective film. Apart from that, the item is complete and fully functional.
For further details, please refer to item number 1022851.
Important: The product images shown are for illustration purposes only and may differ from the actual B-stock item.
Gebrauchte Ware
Radiator dimensions: 395 x 124 x 30mm
Radiator thickness: 29 - 39mm
Radiator size: 360mm
Hose dimensions: 12,7/7,6mm
Base: Nvidia GeForce;
Prefilled: Yes
