B-Ware Alphacool ES Stream LGA 4677 1U
WAC B-Ware Alphacool ES Stream LGA 4677 1U
  • 1025803
  • 4049469342104
  • 0,545 kg
89,98 € * 119,99 € * (25,01% gespart)
This is a B-stock item. The product was used exclusively for creating product photos.... mehr
The product was used exclusively for creating product photos. The packaging is damaged, and the cooler shows minor signs of use in the form of fingerprints. The item is complete and fully functional.
For further information, please refer to item 1023871.
Gebrauchte Ware
Sockel: AMD SP5;Intel LGA 4677;
Abmessungen (L x B x H): 118,50 x 75,50 x 20,50mm
Anschluss: 2x G1/4"
Material Bodenplatte: Kupfer vernickelt
Material Deckel: Acetal;
