Spare parts
Top seller
85%
€1.98 * €12.98 *
Alphacool Aurora LED Flexible Light - Digital RGB 30cm
Content 30 Zentimeter (€53.27 * / 100 Zentimeter)
23%
Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
Content 30 Zentimeter (€33.27 * / 100 Zentimeter)
€9.98 * €12.98 *
Alphacool Aurora LED Flexible Light - Digital RGB 20cm
Content 20 Zentimeter (€69.90 * / 100 Zentimeter)
Close filters
ROH O-Ring 44 x 1,5mm (CPU Alphacool Kühler) O-ring 44 x 1.5mm (CPU Alphacool cooler)
This O-ring is a replacement seal for the popular CPU cooler from Alphacool. It is inserted between the cover and the base. Compatibility: Yellowstone,Livingstone,Niagara,Missouri,XP,XP-Light,Bold,HP Pro Scope of delivery: 1x O-ring 44 x...
€1.69 *
23%
LED Alphacool Aurora LED Flexible Light inkl. Controller - RGB 30cm EOL Alphacool Aurora LED Flexible Light incl. Controller - RGB 30cm
In addition to the Aurora LED rings, Alphacool also offers the Aurora Flexible Light. Like the Aurora LED rings RGB, this flexible light is available in RGB. The power supply is via a 4-pin Molex which can be easily connected to a fan...
€9.98 * €12.98 *
85%
LED Alphacool Aurora LED Flexible Light inkl. Controller - RGB 60cm EOL Alphacool Aurora LED Flexible Light incl. Controller - RGB 60cm
In addition to the Aurora LED rings, Alphacool also offers the Aurora Flexible Leight. Like the Aurora LED rings RGB, this flexible light is available in RGB. The power supply is via a 4-pin Molex which can be easily connected to a fan...
€1.98 * €12.98 *
WACZ Alphacool Eisblock XPX O-Ring Kit - Klar PHT EOL Alphacool Eisblock XPX O-Ring Kit - Clear
Normal 0 21 false false false DE X-NONE X-NONE This set includes two replacement O-rings for the Alphacool Eisblock XPX CPU water cooler. Both O-rings are located around the IN and OUT of the Eisblock XPX cooler and seal the area between...
€3.18 *
LED Alphacool Aurora LED Flexible Light - Digital RGB 20cm Alphacool Aurora LED Flexible Light - Digital RGB 20cm
Nothing remains hidden with the new Alphacool Aurora LED Flexible Light Digital RGB! Every corner of your case is illuminated quickly and easily. The Flexible Lights are available in sizes 5cm, 10cm, 20cm, 30cm and 60cm and therefore fit...
LED Alphacool Aurora LED Flexible Light - Digital RGB 30cm Alphacool Aurora LED Flexible Light - Digital RGB 30cm
WACZ Alphacool Core Backplate XPX/Eisbaer LGA 115X/1200/1700/1851 Metall Alphacool Core Backplate XPX/Eisbaer LGA 115X/1200/1700/1851 Metall
The Alphacool Core metal backplate for XPX, XPX Aurora, XPX Aurora Edge, XPX 1U, XPX Pro 1U, XPX Pro Aurora, Eisbaer, Eisbaer Aurora, Eisbaer Pro, Eisbaer LT is compatible with Intel's LGA 115X, 1200, 1700 and 1851 sockets. This includes...
