Delock MiniPCIe converter mSATA full size - 7 pin
  • 1015886
  • 4043619952403
  • 0,078 kg
This module by Delock converts the mSATA interface into a SATA 7 pin interface. This allows you... more
This module by Delock converts the mSATA interface into a SATA 7 pin interface. This allows you to connect a SATA SSD / HDD to the module. The module is suitable for a full size slot. The SATA connection can be accessed from both sides through the cutout in the middle of the circuit board.
Technical data:
  • Connectors: 1 x mSATA connector > 1 x SATA 7 pin connector
  • Interface: mSATA
  • Form factor: Mini PCIe full size
  • Data transfer rate up to 6 Gb/s
  • Cutout in the middle
  • Dimensions (LxWxH): approx. 51 x 30 x 6 mm
  • OS independent, no driver installation required
System requirements:
  • A free mSATA interface
  • converter
  • 2 screws
  • User manual
83%
€1.49 * €8.98 *
€2.98 *
€6.99 *
€2.58 *
