Anschlussadapter für Ultra-Durchlaufkühler 150 auf G1/4
- Article no.: 17450
- EAN: 4049469090265
- Weight: 0,004 kg
Special adaptor for the Ultra-waterchillers. The adaptor can be inserted instead of the standard fitting and is secured by the standard Union nut.
Technical specifications:
Compatible with Hailea Ultra-waterchiller 150
Material: POM
Suitable for G1/4" threaded fittings
Not compatible with Hailea Ultra Titan 200, 300, 500, 1500 and 2000
A waterchiller required two of these adaptor for full G1/4" connectivity
Note regarding installation:
The adaptor is installed instead of the standard connector of the waterchiller. This requires disassembly of the original connector and reassembly as shown in the image gallery with the adaptor and the fixation screw.
![RAKZ Armaflex AF-1 SK 18mm ID, DSD 8mm (gegen Kondenswasser) 1m selbstklebend](https://aquatuning.shop-cdn.com/media/image/2c/da/19/37016_1Qey41KMET4rMT_200x200..jpg)
![RAK Durchlaufkühler Hailea Ultra Titan 150 (HC130=110Watt Kälteleistung)](https://aquatuning.shop-cdn.com/media/image/8f/ae/29/37023_1YSSDHYdOOZaQm_200x200..jpg)
![RAK Durchlaufkühler Hailea Ultra Titan 150 (HC130=110Watt Kälteleistung) - White Special Edition](https://aquatuning.shop-cdn.com/media/image/56/06/ee/1010999_1rbOfUOZXaNEO7_200x200..jpg)
![WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 mit Backplate EOL](https://aquatuning.shop-cdn.com/media/image/cd/b5/37/1020734_1bNijWe0MUygje_200x200..jpg)
Liefertermin: in 8 - 9 Wochen
![S8 Schlauch PUR 8/5.5mm (1/4"ID) ideal für Steckverbinder Clear Meterware](https://aquatuning.shop-cdn.com/media/image/f7/f1/f5/56001_14hvE0BJFsd3Cq_200x200..jpg)
