Alphacool Eissturm Hurricane Copper 45 2x140mm - Komplettset
  • 11345
  • 4250197113458
  • 5,097 kg
€215.39 *
18547 Alphacool Eiswasser Crystal Blue premixed coolant 1000ml
€12.98*
18548 Alphacool Eiswasser Crystal Clear UV-active premixed coolant 1000ml
€12.98*
18549 Alphacool Eiswasser Crystal Red premixed coolant 1000ml
€12.98*
With the new Eissturm sets you get all the components you need for your start into the world of... more
With the new Eissturm sets you get all the components you need for your start into the world of water cooling. The sets are not only for beginners but also for professionals. All components used are optimally matched and come from Alphacool's high-end series. Alphacool makes no compromises when it comes to materials and relies on pure copper or brass for all metals. This guarantees outstanding cooling performance. With the set you can easily cool your CPU and you can also integrate any graphics card cooler into the circuit. Thanks to the enclosed quick-release fastener, they do not have to empty or modify the circuit.
The products in detail:
Radiator: NexXxoS XT45 Full Copper 280 mm
For many years Alphacool has been a leader in the field of radiators. Due to the consistent use of pure copper for the cooling fins, antechambers and ducts, Alphacool radiators lead the field in terms of performance. The Alphacool NexXxoS radiators offer outstanding performance when using slow-speed fans and offer a high performance reserve when a lot of heat has to be dissipated. This allows them to cover a wide range of applications.
CPU Cooler: XPX
The Alphacool Eisblock XPX cooler has repeatedly been voted the most powerful CPU cooler on the market in independent tests. In addition to excellent workmanship, care was also taken to ensure that the cooler base is large enough for CPUs that rely on eight or more physical CPU cores. If you want to customize your CPU cooler, you can use modding kits from Alphacool. The CPU cover, the screw caps and the mounting frame can be exchanged for other colors.
Reservoir: Eisstation
The Eisstation reservoir is a relatively compact AGB solution with integrated pump top. The pump is completely enclosed by the housing while the water is visible in the transparent nylon housing. Nylon is much more resistant than plexiglass and almost unbreakable. It is mounted either in the "5 ¼" bay or via a Velcro mat that can be positioned freely in the housing.
Pump: DDC310
Alphacool has further optimised the classic DDC pump and with the DDC310 has launched a version that runs extremely quietly and in most cases does not require any further control. The DDC310 is a perfect compromise between performance and volume. It is strong enough to operate even larger water circuits, but remains so quiet that it is barely perceptible from a housing. The design is slightly more compact than that of the VPP755, which can result in an advantage in very narrow housings.
Fans: Eiswind Pure Edition
The new Eiswind fans in the Pure Edition are based on the worldwide popular be quiet! fans. The finely ribbed fan blades ensure optimum air flow and targeted turbulence to minimize background noise. The high-quality rifle bearing also contributes to smooth running. The fans can be controlled via the 4-pin PWM connector. The fans can be controlled over a wide speed range.
Connections and quick-release connector:
Alphacool makes no compromises when it comes to connections. All connections are from the high-end Eiszapfen series and are made entirely of anodized brass. Thanks to the wide ribbed outer surface, the connections can be screwed in very easily. The union nut presses the hose firmly against the connection and contributes to safety. The enclosed quick release fastener makes the set Eisbaer Ready. Many products such as the Eiswolf GPX-Pro cooler, the external water cooling solution Eiswand and other Alphacool products rely on this quick release fastener. In this way, they can easily and quickly combine or separate the products from each other again.
The set includes everything you need for the start. Hoses, the necessary liquid, a filling aid, Y-adapter for the fans and much more. The manual is very extensive with many pictures describing all parts in their function. With an ice storm set you get the perfect set for your water cooling.
Intel: 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 2011 / 2011-3 / 2066 / 1700
Technical data CPU cooler
Produkt:Eisblock XPX CPU - Intel/AMD - Deep Black
Dimensions (LxWxH):65 x 65 x 30mm
Cooler bottom material:Copper
Lid material:Aluminium, sandblasted
Threads:2x G1/4“
Socket compatibility Intel:775 / 1056 / 1155 / 1150 / 1151 / 1200 / 2011 / 2011-3 / 2066 / 1700
Socket compatibility AMD:AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+ / AM4 / AM5
Technical data pump
Product:Laing DDC 310
Voltage range:6 - 13,2 V
Power consumption:10 W
Flow rate:200 L/h
Maximum head:2,4 m
Power connection:4Pin Molex, 3-Pin
Technical data reservoir
Product:Eisstation DDC
Dimensions (LxWxH):102 x 82 x 85mm
Material:Nylon, PMMA
Threads:3x G1/4“ ; 1x G3/8“
Power connection Logo LED:3-Pin
Technical data radiator
Product:NexXxoS XT45 Full Copper 280 mm
Dimensions (LxWxH):324 x 144 x 45 mm
Material:Kupfer
Pressure tested:1,5 bar
Fins per inch:16
Threads:3x G1/4“
Technical data fans
Product:Eiswind Pure Edition 140 - 1350 rpm
Bearing:LLS
Voltage range:5 - 13,2 V DC
Power connection:4-Pin
Rated speed:400 - 1300 rpm
Power consumption:4,8 W
Fan efficiency:130 m³/h
Air pressure:0,97 mm H² 0
Volume:35.8 db (A)
Technical data quick connector
Product:HF Schnellverschlusskupplungsset G1/4
Dimensions (LxD):60 x 26 mm
Threads:2x G1/4“
Material:Nylon
Technical data tube
Product:PVC 13/10mm Ultra Clear 3,3m (BPA free)
Length:3,3 m
Diamater:13/10 mm
Material:PVC
Color:clear
Technical data liquid
Product:CKC Cape Kelvin Catcher
Color:clear
Technical data fittings
Product:Eiszapfen 13/10mm Fitting G1/4
Color:black
Material:Brass
Shape:straight
Threads:G1/4“
Tubing size:13/10 mm
Radiatorgröße: 280mm
Sockel: AMD AM3(+);AMD AM5;AMD AM4;Intel 115x;Intel 2066;Intel LGA 1200;Intel LGA 1700;
Vorbefüllt: Nein
Radiatorabmessung: 324 x 144 x 45 mm
KOI Alphacool Core Storm 420mm ST30 Wasserkühlungs Set
Alphacool Core Storm 420mm ST30 water cooling Set
€349.98 * €369.98 *
KOI Alphacool Core Storm 240mm XT45 Wasserkühlungs Set
Alphacool Core Storm 240mm XT45 water cooling Set
€329.98 * €349.98 *
KOI Alphacool Core Storm 420mm XT45 Wasserkühlungs Set
Alphacool Core Storm 420mm XT45 water cooling Set
€379.98 * €399.98 *
KOI Alphacool Core Hurrican 240mm XT45 HardTube Wasserkühlungs Set
Alphacool Core Hurrican 240mm XT45 HardTube water cooling Set
€399.98 * €419.97 *
Content 3 Stück (€8.66 * / 1 Stück)
€25.98 * €39.25 *
RAD Alphacool NexXxoS ST25 Full Copper 360mm Radiator
Alphacool NexXxoS ST25 Full Copper 360mm radiator
€64.99 * €77.98 *
WACZ Alphacool Eisblock XPX CPU Modding Kit - Blau EOL
Alphacool Eisblock XPX CPU modding kit - blue
€8.29 * €14.79 *
RAD Alphacool NexXxoS ST30 Full Copper 420mm Radiator
Alphacool NexXxoS ST30 Full Copper 420mm radiator
€85.98 * €96.99 *
WAK Alphacool Eisblock Aurora Acetal GPX-A Radeon RX 6800/XT/6900 Reference mit Backplate EOL
Eisblock Aurora Acetal GPX-A Radeon RX 6800/XT/6900 Reference with Backplate
€79.99 * €149.98 *
Hint!
WZS Slotblende mit 2x Schlauchdurchführung EOL
€1.99 * €9.98 *
Alphacool Silver Grease 0,5g
Content 0.5 Gramm (€3,340.00 * / 1000 Gramm)
€1.67 *
S16 Alphacool EPDM Tube 16/10 - Black 1m (3,28ft) Retailbox
€99.98 *
Liefertermin: in 4 - 5 Tagen
Content 30 Zentimeter (€16.60 * / 100 Zentimeter)
€4.98 *
WÄM Alphacool Apex 17W/mK Thermal grease 20g
Content 20 Gramm (€2,999.00 * / 1000 Gramm)
€59.98 *
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Deep Black
Content 4 Stück (€7.25 * / 1 Stück)
€28.98 *
Alphacool Eiszapfen 13/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
€33.98 *
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090 Founders Edition EOL
Alphacool Eisblock Aurora Acryl Active Backplate 3090 Founders Edition
€49.98 * €86.91 *
WAK Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference EOL
€49.98 * €86.98 *
ANF Alphacool ES D-Plug 31,5mm G1/4 AG auf G1/4 AG - Chrome
€8.18 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
WAK Alphacool Eisblock Aurora Acryl GPX-A Radeon RX 6800XT/6900XT MERC 319 mit Backplate
Eisblock Aurora Acryl GPX-A Radeon RX 6800XT/6900XT MERC 319 with Backplate
€74.62 * €139.74 *
Liefertermin: in 2 - 3 Wochen
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 Aorus Master/Xtreme mit Backplate EOL
Eisblock Aurora Acryl GPX-N RTX 3080/3090 Aorus Master/Xtreme with Backplate
€89.99 * €159.97 *
ANK Alphacool ES Distro Plate C1
L22 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
€14.98 * €28.98 *
RAD Alphacool NexXxoS HPE-30 Full Copper 280mm Radiator
€93.98 *
WAGZ Alphacool Eisblock Aurora Terminal flat straight - Acetal
ANZ Alphacool Eiszapfen Verschlussschraube V.2 G1/4 - Deep Black
Alphacool Eiszapfen screw plug V.2 G1/4 - deep black
€3.98 *
WAGZ Alphacool Eisblock GPX Acetal Terminal Abdeckung - Black
Alphacool Eisblock GPX Acetal terminal cover - black
S13 Alphacool Schlauch AlphaTube HF 13/10 (3/8"ID) - UV Rot 1m (3,3ft) Retailbox 100cm
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - UV red 1m (3,3ft) Retailbox
SZ Alphacool Eiskoffer - HardTube saw tool
WAG Alphacool NexXxos GPX Pro Solo mit Backplate - Schwarz
Alphacool NexXxos GPX Pro Solo with backplate - black
€61.79 *
Liefertermin: in 7 - 8 Wochen
