Alphacool HardTube Heat Gun Pro 2000W
- Article no.: 29111
- EAN: 4250197136310
- Weight: 0,888 kg
The Alphacool Heat Gun now complements the extensive HardTube range.
The Heat Gun can be used for a wide range of applications. With high-end power of 2000W which are divided into three levels. The first level can reach a temperature of around 100°C. Level 2 will get to around 350°C and at level 3 an insane 600°C can be reached.
An extra feature is three stable rubber feet on the back of the Heat Gun forming an excellent stand for hands free at work. They also provide safe way to store the gun after it has been used.
Technical data:
- Voltage: 230V
- Power: 2000W
- Current: 8A
- Switch Positions: 0-1-2-3
- Temperature: 100 ° C - 600 ° C
- Air flow: 1 = 250l / min; 2 = 450l / min; 3 = 600 l / min
- Dimensions: 26.5 x 25 x 9cm
- Cable length: 2m
This Heat Gun has an EU plug. If you need the UK plug please see article 1011151.
Downloads: Manual
Liefertermin: in 8 - 9 Wochen
