Alphacool Core Geforce RTX 4090 Master with Backplate
- Article no.: 13478
- EAN: 4250197134781
- Weight: 2,235 kg
Attention: Not compatible with the PCB V1.1!
- Gigabyte AORUS GeForce RTX 4090 Master 24G, 24GB GDDR6X (GV-N4090AORUS M-24GD)
- Gigabyte GeForce RTX 4090 Gaming OC 24G, 24GB GDDR6X (GV-N4090GAMING OC-24GD)
Technical data cooler | |
Dimensions (L x W x H) | 235,80 x 152,96 x 31,90mm |
Threads | 4 x G1/4" |
Thickness cooler bottom | 11,3mm |
Illumination | digital aRGB LEDs |
Number of digital aRGB LEDs | 13 |
Color | transparent |
Technical data backplate | |
Dimensions (L x W x H) | 235,80 x 129,96 x 5mm |
Material | aluminium |
Color | black |
Anschluss: | 4x G1/4" |
Kühlertyp: | Komplettkühler |
Hinweis: | Kompatibel bis 16/13mm gerade;Kompatibel bis 19/13mm gewinkelt; |
Material Deckel: | Acryl [2] |
SLI kompatibel: | Ja |
Hardware Modell: | RTX 4090 ; |
Abmessungen: | 235,80 x 152,96 x 31,90mm |
Liefertermin: in 2 - 3 Wochen
