Alphacool Eiszapfen HF 12mm HardTube compression fitting G1/4 - Deep Black Sixpack
  • 17645
  • 4250197176453
  • 0,115 kg
€24.98 *
Content: 6 Stück (€4.16 * / 1 Stück)
17284 Alphacool Eiszapfen 12mm HardTube compression fitting G1/4 - knurled - deep black
€4.98*
90334 Alphacool Eisplateau Anti-Static work- and mounting mat 120x60cm
€59.98*
17379 Alphacool Eiszapfen 16mm HardTube compression fitting G1/4 - knurled - deep black sixpack
€39.98*
17383 Alphacool HT 13mm HardTube compression fitting G1/4 - knurled - deep black sixpack
€24.98*
18527 Alphacool HardTube 12/10mm Acryl clear 80cm - 4pcs
€16.98*
Alphacool fittings set new standards in terms of design, processing, color scheme, and variety.... more
Alphacool fittings set new standards in terms of design, processing, color scheme, and variety. The remarkably large inner diameter of these fittings more than justifies the name "Highflow".
For every taste
HF HardTube fittings are available in various colors and designs. Alphacool offers the perfect fitting for any application. The product series is perfectly matched and gives every system an individual touch. The combination with Alphacool hoses allows for unlimited creative design possibilities.
Improved chromating process
A new chromating process permanently bonds the intense color of Alphacool fittings with the brass substrate. This ensures that the color does not chip off even after prolonged use. Another highlight is the Alphacool logo on the fittings, underlining the uniqueness of these products.
Dimensions (L x D)18 x 20mm
MaterialBrass, chromatized
Thread sizeG1/4“
Thread length5mm
ColorDeep Black
Warranty: 5 years
Drehbar: Nein
Material: Messing;
Gewindelänge: 5mm
1. Seite: G1/4" Außengewinde
Spezifikation: Form: gerade
2. Seite: 12/10mm
Kompatibilität: Acrylrohre;harte Schläuche (PUR);Carbonrohre;
Farbe: schwarz;
Alphacool fan cable 4-pin to 4-pin extension 30cm
Content 30 Zentimeter (€16.60 * / 100 Zentimeter)
€4.98 *
Alphacool Eiszapfen 16/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
Content 4 Stück (€10.50 * / 1 Stück)
€41.98 *
ANF Alphacool ES D-Plug 20mm G1/4 AG auf G1/4 AG - Deep Black
€7.28 *
RAD Alphacool NexXxoS HPE-45 Full Copper 280mm Radiator
€114.98 *
Alphacool tubing AlphaTube HF 16/10 (3/8"ID) - UV white 3m (9,8ft) Retailbox
L12 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (120x120x25mm)
€9.98 * €12.98 *
WACZ Alphacool Aurora XPX Digital RGB Frame - Black
Alphacool Aurora XPX Digital RGB frame - black
AGZ Alphacool Aurora LED Ring 60mm - Digital RGB
Alphacool Eiswasser Crystal Yellow premixed coolant 1000ml
S12 Alphacool HardTube 12/10mm Acryl (PMMA) Klar 80cm - 4er Set (320cm)
Content 320 Zentimeter (€5.31 * / 100 Zentimeter)
LED Alphacool Aurora LED Flexible Light inkl. Controller - RGB 60cm
Alphacool Aurora LED flexible light 60cm incl. Controller - RGB
Content 60 Zentimeter (€21.63 * / 100 Zentimeter)
€12.98 * €16.97 *
ANS Alphacool HF 16/10 Anschraubtülle G1/4 - Deep Black Sixpack
Alphacool HF 16/10 compression fitting G1/4 - deep black sixpack
€33.98 *
€11.98 *
AGB Alphacool Eisbecher Lite 250mm Acetal Ausgleichsbehälter EOL
Alphacool Eisbecher Lite 250mm Acetal reservoir
€29.99 * €31.99 *
Alphacool D-RAM module (for Alphacool D-RAM cooler) - black 2 pieces
Content 2 Stück (€10.99 * / 1 Stück)
€21.98 *
€26.98 *
Alphacool HardTube 16/13mm Acryl clear 60cm - 4pcs
Content 240 Zentimeter (€7.91 * / 100 Zentimeter)
AGZ Alphacool Acryl Tube 50x213mm (DxH) - Satin
€8.98 * €17.70 *
RAD Alphacool NexXxoS UT60 Full Copper 480mm Radiator
Alphacool NexXxoS UT60 Full Copper 480mm radiator
€119.98 * €156.98 *
€29.98 *
