Yate Loon D80SH-12 mit Stecker (2600rpm) ( 80x80x25mm )
- Article no.: L80
- EAN: 4049469047641
- Weight: 0,08 kg
New fan from Yate Loon. Strong airflow and super-quiet operation speak for this 80mm axial fan with a bronze bearing. The fan can be connected to the PSU via a Molex plug (with adaptor, sold separately) or directly to the Mainboard. The fan is ideal for the super silent operation when operated at <7V. Thanks to the extra long connection cable of approx. 60cm th fan can also be used in very large cases (e.g. Server or Big-tower) and still be properly wired without using cable extensions.
Technical data:
Dimensions: 80x80x25mm
Nominal voltage: 12V
Nominal speed: 2600rpm
Airflow: 32CFM
Noise level: 30 dB(A)
Power consumption: 2,16W
With 3Pin Molex plug, 60cm cable and rpm signal
Farbe Rahmen: | schwarz |
Nennspannung: | 12V DC |
LED: | nicht vorhanden [9] |
Lautstärkebereich: | 30 - 49,9 dB(A) |
Luftförderbereich: | 0 - 49 m³/h [1] |
Stromanschluss: | 3Pin |
RPM Signalübertragung: | Nein |
Größe: | 80mm [6] |
Abmessungen: | 80 x 80 x 25mm |
Leistungsaufnahme: | 2,16W |
Farbe Rotor: | schwarz |
Hersteller: | Yate Loon |
Nenndrehzahl: | 2600 U/min |
Lautstärke: | 30 dB(A) |
Luftförderleistung: | 32 m³/h |
