Noiseblocker NB-BlacksilentFan XC1 ( 80x80x20mm ) 12V DC
  • L80
  • 4250373401690
  • 0,076 kg
€5.80 *
That a quiet and reliable brandname fan doesn't have to cost much has... more
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for years with the Blacksilent series. The ideal compromise between noise levels and power and the low price have made the Blacksilent fans the best-selling silent fans on the market!
Upon frequent customer requests we now offer the XM1/2 in the format 40x40x10mm. Of course these fans also use the superior (((NB))) technology.
Absolute top-notch quality - developed in Germany
In detail:
Original (((Noiseblocker))) quality:
Extremely quiet, reliable and fail-safe
Long-term silent operation:
Speed perfectly suited for silent PCs which allow silent operation over a long lifespan
Maximum safety:
Almost inaudible and extremely long-lived NB-Longlife bearings and a high-grade NB-EKA motor result in an unbeaten failure rate of only 0,01%!
Affordable and cool:
The (((Noiseblocker))) BlackSilent series is one of the most affordable and reliable fan series on the market. The fans were developed in Germany and feature an outstandingly low noise emission as well as great reliability. Unlike with many cheap far-east made fans the noise level remains at it's low level for years.
The reason is the choice of material and precise manufacturing methods. Unlike 95% of the so-called ''fan manufacturers'' (((Noiseblocker))) develops all fans in-house and uses only high-grade parts even in the ''cheaper'' series. The Blacksilent fans were designed to be more simple but just as reliable as the more pricey fan series.
Unlike many competitors we do not give unrealistic technical data. We leave the choice to the customer if claims such as ''400.000hrs MTBF'' are realistic. Just by the way: 400.000 hours are more than 45 years....
With the Rev. 3 of the BlackSilent fan series you purchase a quality product which is optimized for low noise emissions.
The fans are available in the sizes 40, 60, 80, 92 and 120mm. Of each size two versions are available: The 1-series is virtually inaudible and suitable for standard systems. The 2-series has very low noise emission an is powerful enough even for very potent systems.
The rate of failure was further reduced to 0,01% (before 0,15% of 100.000 units). The MTBF was improved with the Rev. 3 to real 80.000hrs
Technical details XC1:
Dimensions : 80x80x20mm
Weight :  60g
Nominal voltage : 12-13,2 V
Starting voltage : <7 Volt
Power consumption : 1,44W
Power draw : 0,12A (max)
Nominal speed : 1700 (+/- 10%)
Dielectric strength : 5 mA (max)
Pressure : 0,860 mm-H2O
Airflow : 35,7 m3/h
Noise level: 18 dB/A
MTBF (25°C) : 50 000 hrs.
Connector : 3 Pin Molex with rpm lead
Nennspannung: 12V DC
Startspannung: 7V
LED: nicht vorhanden
Leistungsaufnahme: 1,44W
Stromanschluss: 3Pin
Luftförderbereich: 0 - 49 m³/h
Größe: 80mm
Nenndrehzahlbereich: 1500 - 1950 U/min
Hersteller: Noiseblocker
Nenndrehzahl: 1700 U/min
Lebensdauer (bei 25°C): 50.000 h
RPM Signalübertragung: Nein
Farbe Rahmen: schwarz
Abmessungen: 80 x 80 x 20mm
Luftförderleistung: 35,7 m³/h
Lautstärke: 18 dB(A)
Farbe Rotor: blau
Content 60 Zentimeter (€8.30 * / 100 Zentimeter)
€4.98 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
48%
WACZ Alphacool Eisblock XPX CPU Ersatz Cover - Rot EOL
Alphacool Eisblock XPX CPU replacement cover - red
€5.09 * €9.79 *
LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm
Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
Content 60 Zentimeter (€11.62 * / 100 Zentimeter)
€6.97 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
RAD Alphacool NexXxoS Monsta 360mm Radiator
Alphacool NexXxoS Monsta 360mm radiator
€149.98 *
€51.98 *
L40 Noiseblocker NB-BlacksilentFan XM1 ( 40x40x10mm )
Noiseblocker NB-BlacksilentFan XM1 ( 40x40x10mm ) 12V DC
€5.85 *
L60 Noiseblocker NB-BlacksilentFan XR2 ( 60x60x25mm )
Noiseblocker NB-BlacksilentFan XR2 ( 60x60x25mm ) 12V DC
€5.99 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
