Noiseblocker NB-BlacksilentFan X1 Rev. 3.0 ( 80x80x25mm )
  • L80
  • 4250051901306
  • 0,098 kg
€7.40 *
The (((Noiseblocker))) BlackSilent series is an inexpensive and reliable ultra silent fan series.... more
The (((Noiseblocker))) BlackSilent series is an inexpensive and reliable ultra silent fan series. The fans are developed in Germany and feature extremely quiet operation as well as high reliability.
Other than the most cheap fans the low noise levels remain for years of operation on their low level.
The reason is the choice of materials and precise manufacturing.
Other than 95% of the so called ''fan brands'' (((Noiseblocker))) develops the fans themselves and uses high quality parts even in their ''cheap'' fans. The BlackSilent fans are simple and solid fans with quality components that naturally have their price.
Different fom other competitors we give only realistic and serious technical data.
We leave it to the customer to judge claims such as ''400 000h MTBF'' (provided by multiple competitors). By the way: 400 000 hours are more than 45 years...
With the Rev. 3 of the BlackSilent series you purchase a reliable product optimized for silent operation.
From now on we include NB-Slics (vibration absorbers) with the 80&92mm retail fans as well as screws with the 120mm versions.
The further improved quality makes us confident that we can elongated the warranty period by one year to 3 years.
The fans are available in the sizes 80, 92 and 120mm.
There are 2 versions of each size: The version 1 is almost inaudible and intended for standard systems, the version 2 is almost not noticeable in operation and developed for more powerful systems.
The failure rate was furthermore improved and is now 0,001% (before 0,15% of 100 000 units p.a.)
The MTBF could be raised to 80 000 realistically with the Rev. 3
Warranty: 36 months
Technical data:
Dimensions: 80x80x25mm
Weight: 65g
Nominal voltage: 12-13,2V
Starting voltage: <5V
Power consumption: 0,48 W
Current: 0,04A
Nominal speed: 1300rpm (+-10%)
Static pressure: 0,680mm H2O
Airflow: 26m3/h
Noise level: 9,7 dB/A
MTBF (25°): 80 000h
Connector: 3 Pin Molex with rpm signal
Farbe Rahmen: schwarz
Nennspannung: 12V DC
Nenndrehzahlbereich: 1000 - 1450 U/min
LED: nicht vorhanden [9]
Luftförderbereich: 0 - 49 m³/h [1]
Stromanschluss: 3Pin
RPM Signalübertragung: Nein
Größe: 80mm [6]
Abmessungen: 80 x 80 x 25mm
Lautstärkebereich: 0 - 9,9 dB(A)
Startspannung: 5V DC
Hersteller: Noiseblocker
Farbe Rotor: blau
Leistungsaufnahme: 0,48W
Nenndrehzahl: 1300 U/min
Luftförderleistung: 26 m³/h
Lautstärke: 9,7 dB(A)
Lebensdauer (bei 25°C): 80.000 h
WAK Alphacool ES RTX 3080/3090 Reference Copper/Carbon mit Backplate EOL
Alphacool ES RTX 3080/3090 Reference Copper/Carbon with Backplate
€89.99 * €159.97 *
WAR Alphacool ES Passive Aluminium Cooler 100x120x22mm
€25.98 *
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
WAZ Alphacool Eiswasser Crystal Blue UV-aktiv Fertiggemisch 1000ml
Alphacool Eiswasser Crystal Blue UV-active premixed coolant 1000ml
PUM Alphacool Laing DDC310 - Single Edition - schwarz
Alphacool Laing DDC310 - Single Edition - black
€55.98 * €78.52 *
RAD Alphacool NexXxoS XT45 Full Copper 80mm Dual Radiator
Alphacool NexXxoS XT45 Full Copper 80mm Dual radiator
€71.98 *
Liefertermin: in 8 - 9 Wochen
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear
Vibrationsdämpfer 80mm Lüfter Schwarz
€2.89 *
L12 Yate Loon D12SH-12 mit Stecker (2200rpm) ( 120x120x25mm ) EOL
Yate Loon D12SH-12 with plug (2200rpm) ( 120x120x25mm )
€2.49 *
