Noiseblocker NB-BlacksilentFan XR2 ( 60x60x25mm ) 12V DC
  • L60
  • 4250051906066
  • 0,071 kg
€5.99 *
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for... more
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for years with the Blacksilent series. The ideal compromise between noise levels and power and the low price have made the Blacksilent fans the best-selling silent fans on the market!
Upon frequent customer requests we now offer the XM1/2 in the format 40x40x10mm. Of course these fans also use the superior (((NB))) technology.
Absolute top-notch quality - developed in Germany
In detail:
Original (((Noiseblocker))) quality:
Extremely quiet, reliable and fail-safe
Long-term silent operation:
Speed perfectly suited for silent PCs which allow silent operation over a long lifespan
Maximum safety:
Almost inaudible and extremely long-lived NB-Longlife bearings and a high-grade NB-EKA motor result in an unbeaten failure rate of only 0,01%!
Affordable and cool:
The (((Noiseblocker))) BlackSilent series is one of the most affordable and reliable fan series on the market. The fans were developed in Germany and feature an outstandingly low noise emission as well as great reliability. Unlike with many cheap far-east made fans the noise level remains at it's low level for years.
The reason is the choice of material and precise manufacturing methods. Unlike 95% of the so-called ''fan manufacturers'' (((Noiseblocker))) develops all fans in-house and uses only high-grade parts even in the ''cheaper'' series. The Blacksilent fans were designed to be more simple but just as reliable as the more pricey fan series.
Unlike many competitors we do not give unrealistic technical data. We leave the choice to the customer if claims such as ''400.000hrs MTBF'' are realistic. Just by the way: 400.000 hours are more than 45 years....
With the Rev. 3 of the BlackSilent fan series you purchase a quality product which is optimized for low noise emissions.
The fans are available in the sizes 40, 60, 80, 92 and 120mm. Of each size two versions are available: The 1-series is virtually inaudible and suitable for standard systems. The 2-series has very low noise emission an is powerful enough even for very potent systems.
The rate of failure was further reduced to 0,01% (before 0,15% of 100.000 units). The MTBF was improved with the Rev. 3 to real 80.000hrs
Warranty: 36 months
Technical details XR2:
Dimensions : 60x60x20mm
Weight :  60g
Nominal voltage : 12-13,2 V
Starting voltage : <7 Volt
Power consumption : 0,9W
Power draw : 0,12A (max)
Nominal speed : 2200 (+/- 10%)
Dielectric strength : 5 mA (max)
Airflow : 24 m3/h
Noise level: 15 dB/A
MTBF (25°C) : 30 000 hrs.
Connector : 3 Pin Molex with rpm lead
Extent of delivery:
1 Fan
4 Vibration absorbers
Nennspannung: 12V DC
Startspannung: 7V
LED: nicht vorhanden
Größe: 60mm
Stromanschluss: 3Pin
Luftförderbereich: 0 - 49 m³/h
Nenndrehzahlbereich: 1500 - 1950 U/min
Hersteller: Noiseblocker
Nenndrehzahl: 1800 U/min
RPM Signalübertragung: Nein
Lebensdauer (bei 25°C): 30.000 h
Farbe Rahmen: schwarz
Luftförderleistung: 24 m³/h
Abmessungen: 60 x 60 x 20mm
Leistungsaufnahme: 0,9W
Lautstärke: 15 dB(A)
Farbe Rotor: blau
WAR Alphacool D-RAM Cooler X4 Universal - Acetal Black Nickel
€54.98 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
€3.98 *
LK Adapter 3Pin (12V) auf 4Pin Molex (12V)
Adaptor 3Pin (12V) to 4Pin Molex (12V)
€1.79 *
€6.99 *
Alphacool y-splitter 3-Pin to 4x 3-Pin 30cm
Content 30 Zentimeter (€11.93 * / 100 Zentimeter)
€3.58 *
€5.28 *
8%
WÄM Alphacool Apex 17W/mK Thermal grease 20g
Content 20 Gramm (€2,749.00 * / 1000 Gramm)
€54.98 * €59.98 *
AGB Alphacool Core Distro Plate 360 Links VPP/D5
Alphacool Core Distro Plate 360 Left VPP/D5
€199.98 *
KOI Alphacool Eisbaer Pro HPE Aurora 360 CPU AIO
€219.98 *
Alphacool Eiszapfen angled adaptor 90° rotatable G1/4 AG to G1/4 IG - 4pcs Set Chrome
Content 4 Stück (€7.25 * / 1 Stück)
€28.98 *
Content 4 Stück (€10.50 * / 1 Stück)
€41.98 *
SEN Alphacool Eiszapfen Temperatursensor flach G1/4 - schwarz
Alphacool Eiszapfen temperature sensor flat G1/4 - Black
WZS Alphacool Spritzflasche Core 250ml
Alphacool Filling bottle Core 250ml
€4.48 *
€65.99 *
WAH Alphacool HDX Apex Acryl aRGB M.2 2280 SSD Kühler
Alphacool HDX Apex Acrylic aRGB M.2 2280 SSD Cooler
47%
29%
L12 Alphacool SL-15 PWM Fan 600-1800rpm ( 120x120x15mm )
€9.98 * €13.98 *
23%
Content 3.5 Gramm (€2,851.43 * / 1000 Gramm)
€9.98 * €12.98 *
RAD Alphacool NexXxoS XT45 Full Copper 1080mm Nova Radiator
€149.98 *
PUZ Alphacool Eisdecke D5 Messing Aufsatz - Deep Black
Alphacool Eisdecke D5 brass top - deep black
€85.98 *
ROH Alphacool Eisbaer GPX Extension Set (Schlauch und Anschlüsse)
Alphacool Eisbaer GPX Extension Set (tubes and fittings)
€13.19 *
PUM Alphacool VPP655 PWM - G1/4 IG inkl. Eisdecke D5 - Acetal V.3
Alphacool VPP655 PWM - G1/4 inner thread including Eisdecke D5 - Acetal V.3
€99.98 * €142.78 *
SEN Durchflussanzeiger G1/4 eckig - Acryl EOL
€12.29 *
