Noiseblocker NB-BlacksilentFan XM2 ( 40x40x10mm ) 12V DC
  • L40
  • 4250051906028
  • 0,04 kg
€4.90 *
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for... more
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for years with the Blacksilent series. The ideal compromise between noise levels and power and the low price have made the Blacksilent fans the best-selling silent fans on the market!
Upon frequent customer requests we now offer the XM1/2 in the format 40x40x10mm. Of course these fans also use the superior (((NB))) technology.
Absolute top-notch quality - developed in Germany
In detail:
Original (((Noiseblocker))) quality:
Extremely quiet, reliable and fail-safe
Long-term silent operation:
Speed perfectly suited for silent PCs which allow silent operation over a long lifespan
Maximum safety:
Almost inaudible and extremely long-lived NB-Longlife bearings and a high-grade NB-EKA motor result in an unbeaten failure rate of only 0,01%!
Affordable and cool:
The (((Noiseblocker))) BlackSilent series is one of the most affordable and reliable fan series on the market. The fans were developed in Germany and feature an outstandingly low noise emission as well as great reliability. Unlike with many cheap far-east made fans the noise level remains at it's low level for years.
The reason is the choice of material and precise manufacturing methods. Unlike 95% of the so-called ''fan manufacturers'' (((Noiseblocker))) develops all fans in-house and uses only high-grade parts even in the ''cheaper'' series. The Blacksilent fans were designed to be more simple but just as reliable as the more pricey fan series.
Unlike many competitors we do not give unrealistic technical data. We leave the choice to the customer if claims such as ''400.000hrs MTBF'' are realistic. Just by the way: 400.000 hours are more than 45 years....
With the Rev. 3 of the BlackSilent fan series you purchase a quality product which is optimized for low noise emissions.
The fans are available in the sizes 40, 60, 80, 92 and 120mm. Of each size two versions are available: The 1-series is virtually inaudible and suitable for standard systems. The 2-series has very low noise emission an is powerful enough even for very potent systems.
The rate of failure was further reduced to 0,01% (before 0,15% of 100.000 units). The MTBF was improved with the Rev. 3 to real 80.000hrs
Warranty: 36 months
Technical details XR2:
Dimensions : 40x40x10mm
Weight :  15g
Nominal voltage : 12 V
Power consumption : 0,48W
Nominal speed : 3800 (+/- 10%)
Dielectric strength : 5 mA (max)
Airflow : 6,7 m3/h
Noise level: 14 dB/A
MTBF (25°C) : 20 000 hrs.
Connector : 3 Pin Molex with rpm lead
Extent of delivery:
1 Fan
4 Vibration absorbers
Nennspannung: 12V DC
Nenndrehzahlbereich: 2000 - 9000 U/min
Luftförderbereich: 0 - 49 m³/h
Farbe Rahmen: schwarz;
Hersteller: Noiseblocker
Größe: 40mm
RPM Signalübertragung: Nein
Leistungsaufnahme: 0,48W
Abmessungen: 40 x 40 x 10mm
Nenndrehzahl: 3800 U/min
Luftförderleistung: 6,7 m³/h
Lautstärke: 14 dB(A)
Lebensdauer (bei 25°C): 20.000 h
Farbe Rotor: blau;
LED: nicht vorhanden;
Stromanschluss: 3Pin;
Alphacool HF compression Fitting TPV Metall - 12,7/7,6mm Straight - Black - 6pcs Kit
Content 6 Stück (€4.66 * / 1 Stück)
€27.98 *
WAC Alphacool Eisblock XPX 1U - Black Acetal Version
€75.98 *
AGB Alphacool Eisstation 40 DC-LT - Behälter
Alphacool Eisstation 40 DC-LT - reservoir
€33.98 *
LZ Vibrationsdämpfer 120mm Lüfter Schwarz
€2.39 *
RAD Alphacool ES Aluminium 120 mm T27 - (For Industry only)
€21.98 *
GHE Alphacool ES 1U - 19" - ServerRack - Watercooling ready
€239.98 *
Alphacool tube AlphaTube TPV 12,7/7,6 - black matte 3,3m (10ft) retail box
Content 330 Zentimeter (€5.75 * / 100 Zentimeter)
Alphacool Eisbaer screw kit M3 x 5/M3 x 30mm
Content 18 Stück (€0.28 * / 1 Stück)
€4.98 *
PUM Alphacool DC-LT 2600 Ultra low noise Ceramic - 12V DC
Alphacool DC-LT 2600 Ultra low noise ceramic - 12V DC
€25.98 *
RAD Alphacool NexXxoS XT45 Full Copper 50mm Dual Radiator
Alphacool NexXxoS XT45 Full Copper 50mm Dual radiator
€39.98 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
L40 Noiseblocker NB-BlacksilentFan XM1 ( 40x40x10mm )
Noiseblocker NB-BlacksilentFan XM1 ( 40x40x10mm ) 12V DC
€5.85 *
L60 Noiseblocker NB-BlacksilentFan XR2 ( 60x60x25mm )
Noiseblocker NB-BlacksilentFan XR2 ( 60x60x25mm ) 12V DC
€5.99 *
