Noiseblocker NB-BlacksilentFan XM1 ( 40x40x10mm ) 12V DC
  • L40
  • 4250051906011
  • 0,04 kg
€5.85 *
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for... more
That a quiet and reliable brandname fan doesn't have to cost much has been proven by us for years with the Blacksilent series. The ideal compromise between noise levels and power and the low price have made the Blacksilent fans the best-selling silent fans on the market!
Upon frequent customer requests we now offer the XM1/2 in the format 40x40x10mm. Of course these fans also use the superior (((NB))) technology.
Absolute top-notch quality - developed in Germany
In detail:
Original (((Noiseblocker))) quality:
Extremely quiet, reliable and fail-safe
Long-term silent operation:
Speed perfectly suited for silent PCs which allow silent operation over a long lifespan
Maximum safety:
Almost inaudible and extremely long-lived NB-Longlife bearings and a high-grade NB-EKA motor result in an unbeaten failure rate of only 0,01%!
Affordable and cool:
The (((Noiseblocker))) BlackSilent series is one of the most affordable and reliable fan series on the market. The fans were developed in Germany and feature an outstandingly low noise emission as well as great reliability. Unlike with many cheap far-east made fans the noise level remains at it's low level for years.
The reason is the choice of material and precise manufacturing methods. Unlike 95% of the so-called ''fan manufacturers'' (((Noiseblocker))) develops all fans in-house and uses only high-grade parts even in the ''cheaper'' series. The Blacksilent fans were designed to be more simple but just as reliable as the more pricey fan series.
Unlike many competitors we do not give unrealistic technical data. We leave the choice to the customer if claims such as ''400.000hrs MTBF'' are realistic. Just by the way: 400.000 hours are more than 45 years....
With the Rev. 3 of the BlackSilent fan series you purchase a quality product which is optimized for low noise emissions.
The fans are available in the sizes 40, 60, 80, 92 and 120mm. Of each size two versions are available: The 1-series is virtually inaudible and suitable for standard systems. The 2-series has very low noise emission an is powerful enough even for very potent systems.
The rate of failure was further reduced to 0,01% (before 0,15% of 100.000 units). The MTBF was improved with the Rev. 3 to real 80.000hrs
Warranty: 36 months
Technical details XR1:
Dimensions : 40x40x10mm
Weight :  15g
Nominal voltage : 12 V
Power consumption : 0,36W
Nominal speed : 2800 (+/- 10%)
Dielectric strength : 5 mA (max)
Airflow : 4,9 m3/h
Noise level: 11 dB/A
MTBF (25°C) : 20 000 hrs.
Connector : 3 Pin Molex with rpm lead
Extent of delivery:
1 Fan
4 Vibration absorbers
Nennspannung: 12V DC
LED: nicht vorhanden
Nenndrehzahlbereich: 2000 - 9000 U/min
Stromanschluss: 3Pin
Luftförderbereich: 0 - 49 m³/h
Hersteller: Noiseblocker
Größe: 40mm
RPM Signalübertragung: Nein
Farbe Rahmen: schwarz
Lautstärke: 11 dB(A)
Abmessungen: 40 x 40 x 10mm
Lebensdauer (bei 25°C): 20.000 h
Leistungsaufnahme: 0,36W
Nenndrehzahl: 2800 U/min
Luftförderleistung: 4,9 m³/h
Farbe Rotor: blau
L40 Noiseblocker NB-BlacksilentFan XM2 ( 40x40x10mm )
Noiseblocker NB-BlacksilentFan XM2 ( 40x40x10mm ) 12V DC
€4.90 *
LK Alphacool Y-Splitter 3-Pin auf 4x 3-Pin 60cm
Alphacool y-splitter 3-Pin to 4x 3-Pin 60cm
Content 60 Zentimeter (€7.45 * / 100 Zentimeter)
€4.47 *
AGB Alphacool Core Distro Plate 240 Links mit VPP Pumpe
Alphacool Core Distro Plate 240 Left with VPP Apex Pump
€199.98 *
L12 Alphacool Core 120mm Lüfter PWM 3000rpm (120x120x25mm)
Alphacool Core 120mm fan PWM 3000rpm (120x120x25mm)
€8.48 *
RAD Alphacool NexXxoS ST30 Full Copper 280mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 280mm radiator V.2
RAD Alphacool NexXxoS ST30 Full Copper X-Flow 280mm Radiator
Alphacool NexXxoS ST30 Full Copper X-Flow 280mm radiator
€59.98 *
LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm
Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
Content 60 Zentimeter (€11.62 * / 100 Zentimeter)
€6.97 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
€51.98 *
L80 Noiseblocker NB-BlacksilentFan XC1 ( 80x80x20mm )
Noiseblocker NB-BlacksilentFan XC1 ( 80x80x20mm ) 12V DC
€5.80 *
LZ Lüftergitter für Axiallüfter für 120mm schwarz
Fan grill for axial fans for 120mm black
€1.99 *
