Noiseblocker NB-BlackSilentPRO PK2 ( 140x140x25mm )
- Article no.: L14
- EAN: 4250051904468
- Weight: 0,217 kg
The new premium fan series is based on the NB-Blacksilent-Chassis and is equipped with the excellent electronics module NB-EKA Plus and NB-NanoSLI bearings. Both are features that were so far used only in the more complex Multiframe series.
Besides the technologically advanced components this fan is also equipped with an individually adaptive cable management.
The fan is shipped with a newly developed mounting kit for vibration-free mounting which consists of an optimized ''NB-Silentframe'' silicone frame with suitable counter-pieces and knurled nuts for tool-free installation.
Technical specifications:
Dimensions: 140x140x25mm
Colour: Black
Weight: 135g
Nominal voltage: 12V
Starting voltage: 4,5V
Current draw: 0,09A
Nominal speed: 1200rpm (+/-10%)
Airflow: 93m³/h / 54,74CFM
Noise emission: 20 dB(A)
MTBF (25°C): 140000hrs
Connector: 3-Pin Molex plug with rpm lead
Extent of delivery:
1x Noiseblocker NB-BlackSilentPRO PK2 ( 140x140x25mm )
1x Fan decoupling
1x 3 PIN fan extension 20cm
1x 3 PIN fan extension 50cm
4x Mounting screws
4x Knurled nuts
This product has been reviewed for you:
Tech-Review
Größe: | 140mm |
Abmessungen: | 140 x 140 x 25mm |
Nennspannung: | 12V DC |
RPM Signalübertragung: | Ja |
LED: | nicht vorhanden |
Stromanschluss: | 3Pin |
Luftförderbereich: | 50 - 99 m³/h |
Lautstärkebereich: | 20 - 29,9 dB(A) |
Nenndrehzahl: | 1200 U/min |
Nenndrehzahlbereich: | 1000 - 1450 U/min |
Hersteller: | Noiseblocker |
Lebensdauer (bei 25°C): | 140.000 h |
Leistungsaufnahme: | 1,08W |
Farbe Rotor: | schwarz |
Farbe Rahmen: | schwarz |
Lautstärke: | 20 dB(A) |
Startspannung: | 4,5V DC |
Luftförderleistung: | 93 m³/h |
Liefertermin: in 8 - 9 Wochen
