Noiseblocker NB-BlackSilentPRO PK1 ( 140x140x25mm )
  • L14
  • 4250051906288
  • 0,223 kg
€18.90 *
The new premium fan series is based on the NB-Blacksilent-Chassis and is equipped with the... more
The new premium fan series is based on the NB-Blacksilent-Chassis and is equipped with the excellent electronics module NB-EKA Plus and NB-NanoSLI bearings. Both are features that were so far used only in the more complex Multiframe series.
Besides the technologically advanced components this fan is also equipped with an individually adaptive cable management.
The fan is shipped with a newly developed mounting kit for vibration-free mounting which consists of an optimized ''NB-Silentframe'' silicone frame with  suitable counter-pieces and knurled nuts for tool-free installation.
Technical specifications:
Dimensions: 140x140x25mm
Colour: Black
Weight: 135g
Nominal voltage: 12V
Starting voltage: 4,5V
Current draw: 0,06A
Nominal speed: 700rpm (+/-10%)
Airflow: 49m³/h / 28,841CFM
Noise emission: 9 dB(A)
MTBF (25°C): 180000hrs
Connector: 3-Pin Molex plug with rpm lead
Extent of delivery:
1x Noiseblocker NB-BlackSilentPRO PK1 ( 140x140x25mm )
1x Fan decoupling
1x 3 PIN fan extension 20cm
1x 3 PIN fan extension 50cm
4x Mounting screws
4x Knurled nuts
This product has been reviewed for you:
Tech-Review
Hardware-academy
Größe: 140mm
Abmessungen: 140 x 140 x 25mm
Farbe Rotor: schwarz;
Nennspannung: 12V DC
RPM Signalübertragung: Ja
Luftförderbereich: 0 - 49 m³/h
Farbe Rahmen: schwarz;
Nenndrehzahlbereich: 0 - 950 U/min
Hersteller: Noiseblocker
Startspannung: 4,5V
Leistungsaufnahme: 0,72W
Lebensdauer (bei 25°C): 180.000 h
Nenndrehzahl: 700 U/min
Luftförderleistung: 49 m³/h
Lautstärke: 9 dB(A)
LED: nicht vorhanden;
Stromanschluss: 3Pin;
Alphacool radiator screw 12x M3x30mm/M3x5mm grey phillips flat head
Content 24 Stück (€0.17 * / 1 Stück)
€3.98 *
Alphacool Universal feet for radiators
Content 2 Stück (€12.49 * / 1 Stück)
€24.98 *
L22 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
€14.98 * €28.98 *
RAD Alphacool NexXxoS XT45 Full Copper 1260mm SuperNova Radiator
€199.98 *
ANK Alphacool HF Schnellverschlusskupplungsset 11/8mm - Black
Alphacool HF quick release connector kit 11/8mm - black
LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm
Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
Content 60 Zentimeter (€11.62 * / 100 Zentimeter)
€6.97 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
LK Phobya Adapter 4Pin Molex (12V) auf 4Pin PWM - Schwarz 30cm
Content 30 Zentimeter (€13.27 * / 100 Zentimeter)
€3.98 *
LK Phobya Y-Kabel 3Pin Molex auf 2x 3Pin Molex - Schwarz 30cm
Content 30 Zentimeter (€11.60 * / 100 Zentimeter)
€3.48 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
€2.98 *
Leak Testing Tool incl. Pump
€34.98 *
PUM Alphacool Eisfach - Single Laing D5 inkl. Alphacool Eispumpe VPP755
Alphacool Eisfach - Single Laing D5 incl. Alphacool Eispumpe VPP755
€86.98 * €124.99 *
ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - Deep Black
Alphacool Eiszapfen screw plug G1/4 - deep black
€2.98 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
Hint!
LK Phobya Verlängerung 3Pin Molex ultra lang -  Schwarz 90cm EOL
Content 90 Zentimeter (€6.09 * / 100 Zentimeter)
€5.48 *
LZ Phobya Lüfterschrauben, 4 Stück (klein) - schwarz
Content 4 Stück (€0.42 * / 1 Stück)
€1.68 *
Hint!
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
Hint!
Content 13 Zentimeter (€9.15 * / 100 Zentimeter)
€1.19 *
LZ Vibrationsdämpfer 120mm Lüfter Schwarz
€2.39 *
ANZ Knickschutzfeder einzeln 13mm (200mm Lang)
€1.59 *
