Noiseblocker NB-BlackSilentPRO PK1 ( 140x140x25mm )
  • L14
  • 4250051906288
  • 0,223 kg
€18.90 *
The new premium fan series is based on the NB-Blacksilent-Chassis and is equipped with the... more
The new premium fan series is based on the NB-Blacksilent-Chassis and is equipped with the excellent electronics module NB-EKA Plus and NB-NanoSLI bearings. Both are features that were so far used only in the more complex Multiframe series.
Besides the technologically advanced components this fan is also equipped with an individually adaptive cable management.
The fan is shipped with a newly developed mounting kit for vibration-free mounting which consists of an optimized ''NB-Silentframe'' silicone frame with  suitable counter-pieces and knurled nuts for tool-free installation.
Technical specifications:
Dimensions: 140x140x25mm
Colour: Black
Weight: 135g
Nominal voltage: 12V
Starting voltage: 4,5V
Current draw: 0,06A
Nominal speed: 700rpm (+/-10%)
Airflow: 49m³/h / 28,841CFM
Noise emission: 9 dB(A)
MTBF (25°C): 180000hrs
Connector: 3-Pin Molex plug with rpm lead
Extent of delivery:
1x Noiseblocker NB-BlackSilentPRO PK1 ( 140x140x25mm )
1x Fan decoupling
1x 3 PIN fan extension 20cm
1x 3 PIN fan extension 50cm
4x Mounting screws
4x Knurled nuts
This product has been reviewed for you:
Tech-Review
Hardware-academy
Farbe Rahmen: schwarz
Nennspannung: 12V DC
RPM Signalübertragung: Ja
LED: nicht vorhanden [9]
Luftförderbereich: 0 - 49 m³/h [1]
Stromanschluss: 3Pin
Größe: 140mm [9]
Abmessungen: 140 x 140 x 25mm
Lautstärkebereich: 0 - 9,9 dB(A)
Nenndrehzahlbereich: 0 - 950 U/min
Hersteller: Noiseblocker
Startspannung: 4,5V DC
Farbe Rotor: schwarz
Leistungsaufnahme: 0,72W
Lebensdauer (bei 25°C): 180.000 h
Nenndrehzahl: 700 U/min
Luftförderleistung: 49 m³/h
Lautstärke: 9 dB(A)
Alphacool Universal feet for radiators
€24.98 *
L22 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (200x200x25mm)
€14.98 * €28.98 *
RAD Alphacool NexXxoS XT45 Full Copper 1260mm SuperNova Radiator
€199.98 *
ANK Alphacool HF Schnellverschlusskupplungsset 11/8mm - Black
Alphacool HF quick release connector kit 11/8mm - black
LK Phobya Y-Kabel 4Pin PWM auf 4x 4Pin PWM - Schwarz 60cm
Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
Content 60 Zentimeter (€11.62 * / 100 Zentimeter)
€6.97 *
LK Phobya 4Pin PWM Verlängerung - Schwarz 90cm
Content 90 Zentimeter (€6.20 * / 100 Zentimeter)
€5.58 *
LK Phobya Adapter 4Pin Molex (12V) auf 4Pin PWM - Schwarz 30cm
Content 30 Zentimeter (€13.27 * / 100 Zentimeter)
€3.98 *
WZS Alphacool ES Big Inline Partikelfilter 2x G1/4" IG
Alphacool ES Big Inline particle filter 2x G1/4" IG
€29.98 *
Liefertermin: in 8 - 9 Wochen
€2.98 *
Leak Testing Tool incl. Pump
€34.98 *
PUM Alphacool Eisfach - Single Laing D5 inkl. Alphacool Eispumpe VPP755
Alphacool Eisfach - Single Laing D5 incl. Alphacool Eispumpe VPP755
€86.98 * €124.99 *
ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - Deep Black
Alphacool Eiszapfen screw plug G1/4 - deep black
€2.98 *
LZ Phobya Lüfterschrauben, 4 Stück (klein) - schwarz
€1.68 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
LZ Vibrationsdämpfer 120mm Lüfter Schwarz
€2.39 *
