Alphacool Eiszyklon Aurora LUX PRO Digital RGB (120x120x25mm)
  • 24806
  • 4250197135986
  • 0,194 kg
€9.98 * €12.98 * (23.11% Saved)
€15.98*
18601 Alphacool Digital RGB LED y-cable 3-times with JST male connector 30cm - black
€7.98*
18602 Alphacool Digital RGB LED y-cable 3-times with JST male connector 60cm - black
€8.98*
18604 Alphacool connection cable 3pin to 3pol Digital RGB - 15cm
€4.48*
You may have already seen the Alphacool Eiszyklon Aurora LUX Pro fan on the Alphacool Eisbaer... more
You may have already seen the Alphacool Eiszyklon Aurora LUX Pro fan on the Alphacool Eisbaer Aurora series. It offers a wide control range as well as outstanding digital RGB LED lighting. The individually controllable 5V aRGB LEDs paired with the special design of the fan frame create unique effects.
Ingenious Lighting
The frame is equipped with digital addressable 5V RGB LEDs which illuminate the whole frame. The frame is not completely transparent, but the illumination is done through narrow slits in four places. On the upper side there are two rows of these slits. Each narrow frame runs along the inside and outside of the frame. This creates a unique illumination which looks very noble. Thanks to the recessed light diffusers the light is distributed evenly. This means that Individual LEDs are no longer visible.
Wide Control Range and Silent
The fan can be controlled from 800 to 2000 rpm via the 4-pin PWM connector. At 800 rpm the fan is almost silent, but still offers a good airflow rate as well as a high static pressure. Therefore, the fan can also be used very well on radiators for a water cooling system. Thanks to the high airflow, the fan is also ideal for ventilating a case. Decouplers are also found directly on the frame. The soft foam padding reduces the transmission of vibrations to the case. A further plus point for the silent capability of the fan.
Connections?
The fan is controlled via a 4-pin PWM connector. The cable is 50 cm long. This allows the fan to be connected to the mainboard or a special controller without any additional adapter cables or extensions. The digital aRGB LED lighting is controlled via a JST 3-pin connector.
Speed800 - 2000 RPM
Static pressure2,0 mm/H2O
Air flow rate104,49 m³/h
BearingsHydraulic
Fan connector4-Pin PWM
Quantity Digital aRGB LED16
Dimensions120 x 120 x 25 mm
Net weight187 g
Max working temperature60 °C
Farbe Rotor: schwarz;
Nennspannung: 12V DC
RPM Signalübertragung: Ja
Lautstärkebereich: 30 - 49,9 dB(A)
Nenndrehzahl: 2000 U/min
Größe: 120mm
Abmessungen: 120 x 120 x 25mm
Luftförderbereich: 100 - 149 m³/h
Nenndrehzahlbereich: 1500 - 1950 U/min
Farbe Rahmen: schwarz;
Leistungsaufnahme: 2W
Druck: 2,00mm H2O
Luftförderleistung: 104,49 m³/h
Lautstärke: 35,6 dB(A)
Stromanschluss: 4Pin;
LED: ARGB;
€4.48 *
L14 Alphacool Eiszyklon Aurora LUX PRO Digital RGB (140x140x25mm)
€12.98 * €19.98 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
L14 Alphacool Rise Aurora 140mm Lüfter (140x140x25mm) EOL
Alphacool Rise Aurora 140mm Fan (140x140x25mm)
€15.98 * €22.98 *
Content 60 Zentimeter (€14.97 * / 100 Zentimeter)
WZS Spritzflasche 250ml PE-LD
€3.59 *
Alphacool Eisbaer Aurora 360 CPU - Digital RGB
€169.98 *
RAD Alphacool NexXxoS ST30 Full Copper 360mm Radiator V.2
Alphacool NexXxoS ST30 Full Copper 360mm radiator V.2
€79.98 * €92.97 *
Alphacool Eisrohr 16/13mm PETG HardTube 80cm - 4pcs
Content 320 Zentimeter (€7.81 * / 100 Zentimeter)
€24.98 *
ANZ Alphacool Eiszapfen Verschlussschraube G1/4 - Deep Black
Alphacool Eiszapfen screw plug G1/4 - deep black
€2.98 *
Content 6 Stück (€5.50 * / 1 Stück)
€32.98 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear
LZ Phobya Lüfterschrauben, 4 Stück (klein) - schwarz
Content 4 Stück (€0.42 * / 1 Stück)
€1.68 *
ANS Alphacool Eiszapfen HF 12mm HardTube Anschraubtülle G1/4  - Deep Black Sixpack
Alphacool Eiszapfen HF 12mm HardTube compression fitting G1/4 - Deep Black Sixpack
Content 6 Stück (€4.16 * / 1 Stück)
€24.98 *
Alphacool Core 1 Aurora Black
€119.98 *
€4.48 *
Alphacool Eiszapfen 13/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
€33.98 *
WACZ Alphacool Backplate mit Schrauben LGA 115x/1200/1700
Alphacool Backplate with Screws LGA 115x/1200/1700
€6.48 *
Alphacool radiator screw 12x M3x30mm/M3x5mm grey phillips flat head
Content 24 Stück (€0.17 * / 1 Stück)
€3.98 *
Content 4 Gramm (€3,995.00 * / 1000 Gramm)
KOI Alphacool Eisbaer Aurora HPE Edition 360 CPU AIO
€179.99 *
€65.99 * €89.23 *
Liefertermin: in 2 - 3 Wochen
WÄM Alphacool Subzero Thermal grease 1g
Content 1 Gramm (€6,980.00 * / 1000 Gramm)
RAD Alphacool ES Aluminium 240 mm T27 - (For Industry only)
€29.98 *
L12 Alphacool Rise Aurora 120 mm Lüfter (120x120x25mm)
€11.98 * €18.98 *
