Phobya 24Pin Netzteil Verlängerung Einzel Sleeving - Schwarz 30cm
  • KAB
  • 4049469100957
  • 0,082 kg
€2.58 *
Content: 30 Zentimeter (€8.60 * / 100 Zentimeter)
  An extension for 24-Pin ATX12V 2.0, EPS, WTX and ATX-GES power connectors. This... more
An extension for 24-Pin ATX12V 2.0, EPS, WTX and ATX-GES power connectors. This extension is usually used to extend the 24Pin cable from the PSU to the Mainboard if e.g. the Mainboard is mounted inverted or when using a bigtower.
Extent of delivery:
1x Phobya extension 24-Pin PSU, single sleeved 30cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
Extremehardware (it.)
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 60cm
€5.68 *
LK Phobya Adapter USB (5V) Extern auf 3Pin Lüfter - Schwarz 30cm
79%
KAB Alphacool 4Pin Molex einfach Adapter für Alphacool Magnetventil - schwarz 50cm EOL
Alphacool 4Pin Molex single adapter for Alphacool magnetic valve 50cm - black
Content 50 Zentimeter (€3.38 * / 100 Zentimeter)
€1.69 * €7.98 *
81%
Alphacool 4Pin Molex double adapter for Alphacool magnetic valve 50cm - black
€1.69 * €8.98 *
LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL
Content 60 Zentimeter (€12.47 * / 100 Zentimeter)
€7.48 *
53%
ZSO Alphacool Eistools Montagehandschuhe Größe L - Black
Alphacool Eistools modding gloves size L - Black
€1.48 * €3.18 *
LZ Phobya 4Pin PWM auf 8x 4Pin Splitter EOL
€8.48 *
WZS Spritzflasche 500ml PE-LD
€4.19 *
Alphacool Digital RGB LED y-cable 3-times with JST male connector 60cm - black
56%
MKA Alphacool AlphaCord Sleeve 4mm - 3,3m (10ft) - Black (Paracord 550 Typ 3) 330cm
€1.98 * €4.47 *
48%
WACZ Alphacool Eisblock XPX CPU Ersatz Cover - Rot EOL
Alphacool Eisblock XPX CPU replacement cover - red
€5.09 * €9.79 *
PUZ Laing Kunststoff Pumpenaufsatz 1/2 Schlauchanschluss
WZS Alphacool Eiszapfen Filter G1/4 IG - Acryl
Alphacool Eiszapfen filter G1/4 inner thread - Acryl
€11.98 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 60cm EOL
€5.28 *
€1.88 *
ZK Phobya Connector 2Pin Stecker inkl. 2 Pins - 10 Stück Black EOL
Content 10 Stück (€0.09 * / 1 Stück)
€0.90 *
Alphacool tubing AlphaTube HF 13/10 (3/8"ID) - clear 3m (9,8ft) Retailbox
LZ Phobya Lüfterfilter 120mm - schwarz EOL
€3.98 *
PUZ Laing Pumpenfuß für D5 Vario EOL
€9.99 *
LK Phobya Verlängerung 3Pin - Schwarz 30cm EOL
Content 30 Zentimeter (€10.60 * / 100 Zentimeter)
€3.18 *
45%
KAB Alphacool Eiskamm Alu X16 - 4mm black - 4 Stück EOL
Alphacool Eiskamm Alu X16 - 4mm black - 4 pcs
Content 4 Stück (€1.37 * / 1 Stück)
€5.49 * €9.94 *
€5.68 *
€3.97 *
€2.78 *
€2.58 *
Alphacool y-splitter 3-Pin to 3x 3-Pin 30cm
€2.98 *
€5.28 *
AGB Alphacool Core Distro Plate 240 Links mit VPP Pumpe
Alphacool Core Distro Plate 240 Left with VPP Apex Pump
€199.98 *
Content 2 Stück (€14.99 * / 1 Stück)
€29.98 *
Content 4 Stück (€6.75 * / 1 Stück)
€26.98 *
€26.98 *
Alphacool Eiszapfen 13/10mm compression fitting 90° rotatable G1/4 - 4pcs Set Deep Black
€33.98 *
27%
L12 Alphacool Rise Aurora 120mm Lüfter Weiß (120x120x25mm)
€15.98 * €21.98 *
Alphacool radiator screw 12x M3x30mm/M3x5mm grey phillips flat head
Content 24 Stück (€0.17 * / 1 Stück)
€3.98 *
