Alphacool PWM to Mainboard PWM 40cm black
KAB Alphacool PWM auf Mainboard PWM 40cm schwarz
  • 18715
  • 4250197187152
  • 0,015 kg
€4.48 *
18600 Alphacool Eis-Matrix connection cable - 10cm
€1.59*
€15.98*
18602 Alphacool Digital RGB LED y-cable 3-times with JST male connector 60cm - black
€8.98*
18619 Alphacool Eis-Matrix II - Adapter 5-Pin auf PWM + 5V Digital RGB (3pcs)
€4.47*
17636 Alphacool Apex PCI-e 4.0 Riser cable - 20cm
€74.98*
Sleeved PWM to motherboard PWM cable with a length of 40cm for connecting two components.... more
Length 40cm
Connections PWM to mainboard PWM
Weight 9g
Color black
KAB Phobya 4Pin Molex Stromverlängerung - Schwarz 60cm
€5.68 *
KAB Phobya RGB 4pol Verlängerung - Schwarz 150cm
Content 150 Zentimeter (€2.45 * / 100 Zentimeter)
€3.68 *
LED Alphacool Aurora LED RGB Controller Kompakt
Alphacool Aurora LED RGB Controller compact
€4.97 * €9.98 *
Alphacool y-cable RGB 4pol to 3x 4pol 60cm incl. connector - black
€2.98 *
€4.48 *
€4.48 *
RAD Alphacool NexXxoS HPE-45 Full Copper 360mm Radiator
€109.98 * €124.99 *
WAK Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 mit Backplate EOL
Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 with Backplate
€89.99 * €159.97 *
S12 Alphacool HardTube 12/10mm Acryl (PMMA) Klar 60cm - 4er Set (240cm)
Alphacool HardTube 12/10mm Acryl clear 60cm - 4pcs
Content 240 Zentimeter (€5.83 * / 100 Zentimeter)
Alphacool Eisrohr 13/10mm Acryl (PMMA) HardTube satin 80cm - 4pcs
€23.98 *
€26.98 *
LK Phobya Y-Kabel 4Pin PWM auf 6x 4Pin PWM - Schwarz 60cm EOL
Content 60 Zentimeter (€12.47 * / 100 Zentimeter)
€7.48 *
ZK Phobya Fan Power Connector Pin Buchse - 20 Stück EOL
€2.48 *
LK Phobya Adapter 4Pin Molex (12V) auf 4Pin PWM - Schwarz 30cm
Content 30 Zentimeter (€13.27 * / 100 Zentimeter)
€3.98 *
LK Phobya Y-Kabel 4Pin PWM auf 3x 4Pin PWM - Schwarz 30cm
€4.48 *
LZ Vibrationsdämpfer 120mm Lüfter Schwarz
€2.39 *
LZ Lüftergitter für Axiallüfter für 120mm schwarz
Fan grill for axial fans for 120mm black
€1.99 *
