Phobya Y-cable 4Pin PWM to 4x 4Pin PWM 60cm - black
- Article no.: 1011110
- EAN: 4049469193362
- Weight: 0,029 kg
A Y-cable to connect 4x4-Pin PWM fans to one 4-Pin PWM connector.
As fan control via the Mainboard with a PWM fan is much more affordable than a fan controller, this cable is perfect to give more flexibility.
The extension cable is sleeved with a black mesh which additionally protects the cable and looks great! This further expands the lifespan of the cable. The ends towards the connectors are fixated with heatshrink for a clean finish.
A white marking on one of the split cables shows from which cable the rpm signal is transmitted.
Sleeving:
The idea behind these cables:
Technical specifications:
Connectors:
1x 4-Pin PWM male
4x 4-Pin PWM female
Colour: Black sleeve, black connectors, black heatshrink
Dimensions: Overall 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya Y-cable 4-Pin PWM to 4x4-Pin PWM 60cm - black
Bauform: | Y-Kabel |
1. Seite: | 1x 4Pin PWM |
2. Seite: | 4x 4Pin PWM |
Sleeving: | schwarz |
Hersteller: | Phobya |
Liefertermin: in 7 - 8 Wochen
