Phobya Verlängerung 3Pin Molex extra lang - Schwarz 60cm
  • LK
  • 4049469077921
  • 0,008 kg
€4.48 *
Content: 60 Zentimeter (€7.47 * / 100 Zentimeter)
Liefertermin: in 2 - 3 Wochen
Extension cable for 3-Pin cables e.g. for fans. With rpm signal lead. Sleeving: This cable... more
Sleeving:
Sets:
Technical specifications:
Connectors: 3-Pin extension
Black sleeve, black connectors and black heatshrink
Length: 60cm
Conforms with RoHS
Extent of delivery:
1x Phobya extension cable 3-Pin Molex 60cm - black
This product has been reviewed for you:
Aquainfos
Tech-Review
1. Seite: 1x 3Pin Molex
2. Seite: 1x 3Pin Molex
Sleeving: schwarz
Hersteller: Phobya
Bauform: Verlängerung
€1.19 *
Content 30 Zentimeter (€2.17 * / 100 Zentimeter)
€0.65 *
€5.68 *
LK Phobya Y-Kabel 3Pin Molex auf 9x 3Pin Molex -  Schwarz 60cm EOL
